Hotpoint fetc70 keeps cutting out
Home Forums Public Support Forums Help And Support Tumble Dryer Help Forum Hotpoint fetc70 keeps cutting out
  • #101680
    Leeberry50
    The dryer runs for around 10 minutes then just stops, I have to open the door and close it again and then press start and it then works for about 20 min. I repeat then it will usually run to the end of the cycle 30/40 min.
    all filters clean, water is empty, condenser is clean.
    any suggestions?
    #485660
    is that on a sensor dry or timed setting
    try a timed dry and see what it does then
    Leeberry50
    It doesn’t have sense dry. It’s just a timer
    #485662
    ok i see i did not look it up and most are electronic these days
    yours is a simple unit
    first off try another socket it not the first time i have had faulty sockets causing problems like this. if the power get interupted for 2 secs the relay will drop out
    if that is ok check the terminal block and supressor where the wire goes in
    Leeberry50
    Thanks Dave, yes it’s just a simple one.
    Where are the suppressor and terminal block?
    #485664
    where the mains flex enters the machine
    Leeberry50
    Great thanks will check out tomorrow
    #485666
    Leeberry50
    Hi, I have used a different outlet altogether and checked all the connections on the terminal block all are secure and still have same issue. Any other suggestions please
    #485667
    does it restart right away when it stops ?
    Leeberry50
    No, I have to open the door, close it then press start
    #485669
    ok then it does sound like a possible door lock problem
    Leeberry50
    Ok, do you know the part needed?
    FETC70BP uk is the full model number
    #485671
    kaibart
    The part number for the door lock is C00195695
    #485672
    Leeberry50
    Thanks for the advice. Replaced the part and is now working properly
