Re: hotpoint few 10p advice please
If you have not seen it yet then I suggest you go and take a look first,
Some FEW10’s have a sealed drum. 😉
Also the ones with the screwed drums can have either 30mm or 35mm bearings and shaft.
Both types of bearing kits are available but you cannot get a 30mm spider only the 35mm one.
Ring the customer and ask them if there is a black pump filter behind the lower front plinth. If there is then it has the sealed outer drum in it.
