Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint FEW 12
- This topic has 14 replies, 6 voices, and was last updated 18 years, 10 months ago by
Alanj.
May 21, 2007 at 6:27 pm #27513
Alanj
ParticipantHi guys,
Just wanted some practical info regarding bearing job on above machine.I have tended to give bearing jobs on these machines a wide berth. Thought I’d bite the bullet and give it a go. What is the routine for dismantling machine to remove drum and then bearings?
Thanks in advance
Alan.May 21, 2007 at 6:57 pm #214416wilf
ParticipantRe: Hotpoint FEW 12
I dont try to get the bearing out just fit tub rear half and spider if required (cut through the fixing bolts with an angle grinder) I usually take the tub back to the workshop to strip and re build then take it back to re assemble
wilf
May 21, 2007 at 7:08 pm #214417timdowning
lid off.
front off.
remove dispenser, valve, wiring, concrete weights.
lay machine on back.
remove sump hose.
take out suspension pins. (push in barb and pull pin forward).
lift out tub assy.
remove motor and wiring that is ty-wrapped to tub.something along those lines.
May 21, 2007 at 7:17 pm #214418hotpnt
wow whats all this about angle grinding the support screws off??!!, just unscrew them, dead easy, take a torx bit, insert, hit 3 times HARD, then try to tighten the screw, (will only turn about 2{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} but you will see it go) then unscrew, never fails if done right
May 21, 2007 at 7:34 pm #214419Alanj
Hi Hotpnt,
these screw heads do look pretty corroded.If they don’t screw out will they drill out? 😳
Alan
May 21, 2007 at 7:36 pm #214420Simon46
yes 8mm titanium bit. then fit new screws.
Regards
S.May 21, 2007 at 8:28 pm #214421Alanj
OK they do drill out 😆 anyone got a part number for replacement screws 💡 😳 .
Alan
May 21, 2007 at 8:32 pm #214422Penguin45
Machine is at most 3 years old – why are you not refering it back to Hotpoint? Unless you’re going to bring the job in for under £90, which would be ridiculous given the work involved.
May 21, 2007 at 8:46 pm #214423Alanj
Chris,
it was in a commercial premises and hotpoint wouldn’t fix it under warranty.Alan
May 21, 2007 at 8:47 pm #214424Penguin45
In that case, charge them a bl@@dy fortune 😀 😀
May 21, 2007 at 8:53 pm #214425Alanj
Chris,
it was a bit of an experiment for me, because I have not tried doing a rear drum change on one of these. I don’t think I’ll be doing any more. I usually do pass them onto Hotpoint under warranty.Alan
P.S. you don’t have a part number for them drum support fixing screws do you?
May 21, 2007 at 8:58 pm #214426Penguin45
1603354
May 21, 2007 at 9:06 pm #214427Alanj
Thanks Chris,
did have the part number, eventually got it to come up on Masterpart.
Alan
May 21, 2007 at 9:06 pm #214428timdowning
Its all well and good refering people back to Hotpoint but it depends on your call-out charge. If like me your call-out is £18 plus vat you can’t keep affording to give work away. I always give people the choice of going back to hotpoint under the 5 years but it’s surprising how many don’t want to.
My normal charge for bearing change on a WMA is £129.
Yes Hotpoint would do it for £94 but the customer has also paid me £21.15 for calling-out.
I would love to charge £40, or more, call-out and then refer the customer back to Hotpoint. I would never have to get my hands dirty.
May 21, 2007 at 9:07 pm #214429Alanj
it’s been a long day 😯 ❗
Alan -
