Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › HOTPOINT FEW 12
- This topic has 7 replies, 4 voices, and was last updated 15 years, 8 months ago by
Batchfield.
July 31, 2010 at 1:45 pm #56199
Batchfield
ParticipantHoping for some help with my hotpoint.
The machine is not rinsing or spinning as part of the normal cycle, but seems happy to progress only if the cycle is stopped and the controller is set to “spin”. The machine cannot be pursuaded to rinse at any time.
Drain and filter are clear.
Many thanks
July 31, 2010 at 2:36 pm #326520iadom
ModeratorRe: HOTPOINT FEW 12
Does it actually fill with cold water during the rinse cycle?
July 31, 2010 at 3:51 pm #326521Batchfield
ParticipantRe: HOTPOINT FEW 12
No, it does not seem to get into the rinse cycle – it seems to wash then stop.
July 31, 2010 at 6:16 pm #326522helo_75
Participantwhat iadom is saying is that it sounds like a faulty cold inlet valve
July 31, 2010 at 7:33 pm #326523Batchfield
the machine is only cold fill and so will fill for the intial wash, though. Another site suggests a heater fault?
August 1, 2010 at 10:11 am #326524magglyn
There is a test sequence that you can perform.
With door closed. Press and hold the two option buttons. Select ‘D’ keep buttons held for approx 5 secs, all light flash. Push start, select prog ‘A’ without going through ‘Off’ position, push start.
Machine should now
Fill through wash valve
Rinse valve
Both valves
Drum rotation+heating
Drain
SpinAugust 1, 2010 at 10:24 am #326525iadom
Batchfield wrote:the machine is only cold fill and so will fill for the intial wash, though. Another site suggests a heater fault?
The fill valve is a double valve, the rinse valve can fail but the machine will still fill for the initial wash cycle.
Does it wash, drain out and then stop?
Which was the ‘other site’ giving you totally incorrect information? The heater has no effect on the rinse cycle. :rolls:
August 3, 2010 at 5:55 am #326526Batchfield
Forget which website suggested an earth fault on the heating element that would cause the machine to stop at the end of the was cycle – was either somewhere on fixya or howtomendit.
Yes, the machine is washing and then stopping.
I’ll try the test sequence when I get home. Thanks. 🙂
