Re: Hotpoint FF187E PL module to set up
Not done a top mounted module one yeat but have done several of the rear mounted types which do not need the low end adaptor.
If you buy a used low end adaptor, bare in mind that it must be marked “2007” as the older version will not work, a lot of us bought the original version which is next to useless these days.
You should have instructions about programming either with your smart card reader or with the new pcb. Not had any problems doing one of these yet but the green light that is supposed to indicate a succesful install has never come on (IIRC) although the appliances have worked ok.
