hotpoint ff187m
  • #52529
    Johnnyboy
    hi all
    have a problem with a ff187 complaint internal light flashing when door was opened took this as a warning ,ordered top fascia pcb
    but sadly fault still persists does this pcb need programmed or can any shed any light on this fault (have noticed that their is another module at the base of the appliance) thanks for any advice
    #312161
    geoff1
    Re: hotpoint ff187m
    hI
    With this unit the internal light flashes after the door has been opened for more than 2 mins.
    Check that the light switch is being activated by running a magnet along control panel to see if light goes out. there should be a reed switch built into control panel and a magnet into door.
    Hope this helps
    Geoff
