Hotpoint FF200E Fridge Freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint FF200E Fridge Freezer
Viewing 15 posts - 1 through 15 (of 15 total)
  • #36483
    roly16
    The evaporator is icing up solid. The heater is ok and the thermistors appear ok; their resistance is changing with temperature anyway. Is it likely to be anything other than the main pcb at the back? The thermistors are foamed in and looking at Partfinder they don’t seem to be replacable anyway.
    Geoff
    #251168
    johnnyj
    Re: Hotpoint FF200E Fridge Freezer
    There is a mod kit available to cure new defrost heaters and cutouts and aluminuim foil to beplaced behind evaporator, before ser n/o begining 71008 use C00259476 and after 71008 use C00759745 cheers jj
    #251169
    roly16
    Thanks Jonny. I went back into Partfinder armed with that info and there is a window that tells you about it.
    #251170
    Hollytree_Technical
    Can anyone send me the service bulletin (and service manual if your feeling extra generous) for these machines please – just been to see one today where there was a couple of inches of ice hanging from the evaporator – thermistors, thermal fuses and defrost heater all meter as ok.
    If not can anyone shed some light on exactly which bit has gone as I am reluctant to get a board if it isn’t that which is causing the fault.
    Thank you
    Jem
    #251171
    BobHope
    hi Jem,
    you have email.
    Bob.
    #251172
    Hollytree_Technical
    Thank you Bob – all received. 😀
    Quick question for anyone who has done the mod – Am I right in thinking that the new heater extends lower than the old one or is that just the model in the picture?
    Thank you.
    Jem
    #251173
    BobHope
    Hi Jem,
    the new heater is larger and extend down to the fridge air return slot to stop it iceing over.
    Bob.
    #251174
    Hollytree_Technical
    Thank you Bob – looks like I will be ordering a new heater then as the customer was shocked at the size of the lump of ice that I removed this morning.
    Jem
    #251175
    A1_Domestics
    I’ld appreciate some help with this too. Got one to look at in the morning.
    #251176
    BobHope
    email sent
    Bob.
    #251177
    jongriffin
    can anyone send me the info as well please…getting quite a few of these lately
    thanks
    #251178
    Hollytree_Technical
    Check your e-mail
    Jem
    #251179
    jongriffin
    Thats very useful thanks
    jon
    #251180
    mic
    Hi I see this is an old thread but if anyone could send us the info it would be really helpful
    Wendy
    #251181
    Hollytree_Technical
    PM me an email address and I will see what I can do.
    Jem
