Re: hotpoint ff200mx display board dead
all the display board I have seen are not fused. they will only be fed with 12v or so from the power board. if the display board is part functioning look at display with a torch. may be the back lights are off if its LCD, got a hotpoint dryer with that problem. If its only display off then maybe a blown resistor on display panel. if other functions of the panel function ok then most likely only the display
but bear in mind , they are powered from the main board so it may be a display fault or a power board fault or both
