This One is giving me the run around
Fault – freezer runs at -22 and the fridge at about +18.
Condesnor fan running
Baffle open
Flow and return pipes to fridge clear
thermistors seem to be reading correct values.
ok on self dia test.
But here is the issue.
The evaporater fan is hit and miss when it runs and how long for.
IE open and shut the fridge door and the fan will run for 3 seconds or 3 mins or maybe longer.
Door switch is not a problem and I have spaced door up to ensure it is hitting the switch
When the fan stops the feed at from the module also disappears.
Can this be a fault with module or have I missed something???
If it is module connect have it as programmed requires configeration – How??
Help
Geoff
