Hotpoint FF72P Dead!!
  • #35759
    dan0k5
    Hi, Just got a Hotpoint FF72P fridge freezer off ebay. Got it home, spruced it up, and left it to settle for a few hours. Plugged it in, all worked great.
    I realsied the fridge light bulb had blown, so i removed it. Realising I didnt have another bulb the same I put the old bulb back into the holder as to stop any moisture penetrating it etc. And the bulb made a white flash and a pop, and the whole thing went dead.
    I have tried in different sockets and changed the fuse, but no signs of life, nothing on the display or anything.
    Any ideas on this one??
    #247976
    hotpnt
    Re: Hotpoint FF72P Dead!!
    that does not sound good, if you have tried the fuse & still all dead you may well have blown the main control module
    #247977
    dan0k5
    Not at all good!
    And looking at the cost of the part in your shop!! 😯
    I have no idea what I can do now. Do I get it repaired, or simply move it on!!
    #247978
    hotpnt
    how much did you pay for it first? and second can you give a serial number to check the age
    #247979
    helo_75
    i had one of these just yesterday, customer put a bulb in and it blew up, and yes it was the control board, blown to pieces
    i had to repair the edge connector as well
    not a good fridge freezer at all
    #247980
    There is another point to this..Which is !
    Having the bulb changed should not cause a board failure to this extent which would point to a design fault.
    Yes we all know that the power should be turned off but even a bulb blowing on this model causes the same outcome which consumers cannot control.
    Bryan
    #247981
    helo_75
    its a good point, and your right
    but, what do people do? do theyre suppsed to power off when changing lightbulbs… dont they turn the switch off to change a house light?
    i see where your coming from, but there really isnt an argument at all.. we always recommend unplugging before commencing any work
