Hotpoint FF72S not cold enough
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint FF72S not cold enough
  • #81400
    MARIO
    Hi can anyone help have got a Hotpoint FF72S S/N 78186331.Freezer temp fluctuating from -11 to -17.Fridge not cold at all. Condenser was blocked so cleaned still no improvement. Carried out self diagnostic check which it did but no fault detected. Hate these fridges always trouble if anyone can help will be much appreciated.
    #416487
    MARIO
    Re: Hotpoint FF72S not cold enough
    Hi again can anyone help there must be somebody who deals with this rubbish.
    #416488
    SAMURI
    Take everything out of the fridge freezer and get someone to look after it for you.
    Then turn it off and try a 48 hour defrost and leave the doors open.
    When you turn it back on it should work ok after 2 to 4 hours.
    If the problem returns in a few weeks the defrost heater is most likely faulty.
    Bob
    #416489
    MARIO
    Thanks for the reply Bob but have looked behind back panel in freezer and its not iced up.Is it this model where it has to get to -15 before the evap. fan starts as the fan runs when in test mode but not when running normally and no faults present after carrying out test mode.
    #416490
    johnnyj
    Change the evaporator thermistor usualy cures it other than that might be fan motor even though it runs in test mode, they sometimes are faulty.
