Hotpoint FF91 Frost Free – Fridge not getting cold
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint FF91 Frost Free – Fridge not getting cold
  • #72438
    Iamdbat
    I haven’t worked on Frost Free before – The Fridge is not getting cold – would anyone have a good idea of what I should be looking for?
    #384522
    Iamdbat
    #384523
    Re: Hotpoint FF91 Frost Free – Fridge not getting cold
    tip #1 post in the correct forum.
    tip #2 give us a bit more detail to go on, this literaly could be anything.
    assuming the the compressor is running, check for over freezing of the evaporator in the freezer which may prevent airflow into the fridge.
    #384524
    Dragan
    I have checked but there is no Hotpoint combis model FF91!?
    If you have any experience and required tools you must use it!
    I have the impression that you were afraid.
    Be brave and finish that job!
    Dragan
    #384525
    Iamdbat
    Dragan wrote:Hi,
    Dragan
    Ehhhh….. What exactly are you on about FF91P Mistral is a model – I haven’t looked at the fridge yet but I haven’t worked on Frost Free before and no I’m not afraid – the job is for my brother in law – I was hoping to get some pointers from somebody who had worked on them before that’s all
    #384526
    Dales-Electronic
    OK then – switch it off and take out the freezer baskets. If the back panel is removable carefully remove them but be aware that it might be stuck in place with ice, in which case allow the appliance to fully defrost and then remove the panel. Check that the flow and return vents are clear of ice and that the evaporator is similarly free of ice build up. Put it back together and see what happens. If it freezes up again come back to us and we’ll take you to the next stage, if its OK then a cheap fix
