Hotpoint FF91 Mistral Fridge/Freezer
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint FF91 Mistral Fridge/Freezer
  • #7123
    ipoole
    Hi There
    My first post on here. I`ve been called out to a Hotpoint Frost Free FF91. Everything appears to work OK apart from the fact that the fridge thermistor doesn`t appear to sense the fridge temperature, hence the compressor keeps running and eventually the evaporator ices up resulting in the temperature in the fridge rising. I`ve changed the thermistor but it didn`t cure the problem. Any ideas?
    #121500
    Simon46
    Re: Hotpoint FF91 Mistral Fridge/Freezer
    Is the fan running in the freezer? Also does the light go out when fridge door is closed?
    #121501
    ipoole
    Yep, the fan is running, the light goes out when the door is shut, it`s just that whatever the temperature in the fridge the display reads 19oC, and eventually the temp does rise to 19
    #121502
    Ray9500
    I’ve found that replacing both the thermistors in the freezer cures a multitude of sins 😉
    Ray
    #121503
    roly16
    Have you checked continuity across the fridge thermistor from the pcb itself to ensure there’s good contact at the edge connector? Geoff
    #121504
    clyde
    The evaporator thermisor is most likely at fault part no 2601683. It doesn’t like moisture can provide dodgy readings!
    if you do a resistance check of the thermistor the approx readings should be
    +20’C 3K ohms
    0’C 9K ohms
    -5’C 11K ohms
    -20’C 26 K ohms
    Hope this helps
    Clyde
    #121505
    ipoole
    Thanks for your help everyone. I going to also replace the thermistors in the freezer. I`ll let you know the result next week
    ipoole
