Hotpoint FF93S is it time to buy a new one?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint FF93S is it time to buy a new one?
  • #29544
    leginjc
    Hi I have a Hotpoint FF93S which is 6 years old. I have read all the advice re fridge not cooling and so far both thermistors have been changed and today Hotpoint also replaced the Module Procond 3 (control unit?). The problem still remains though.
    Freezer reading -22 and working
    Fridge reading +23 and not working
    The unit has been defrosted cleaned etc does anyone have any ideas on what may be the cause or should I give up and buy a new FF?
    Any advice would be appreciated.
    #223553
    Re: Hotpoint FF93S is it time to buy a new one?
    If you’ve paid Hotpoint to fix it I’d get them back to put it right.
    leginjc
    kwatt wrote:If you’ve paid Hotpoint to fix it I’d get them back to put it right.
    Thanks Kwatt, I have an extended breakdown policy which as it stands I can get my money back on or I can continue to pursue the repair! Trouble is I don’t think they (Hotpoint) know what to do next!
    #223555
    If it is 6 years old then you’re likely to get a “contribution” to a new one if it can’t be repaired, not a straight replacement machine in most cases. Of course that depends on the policy but for most this will apply after the initial five years is up.
    Given that you’d likely get less than half the value of a new one if that’s case it may be better to pursue a repair.
    leginjc
    kwatt wrote:If it is 6 years old then you’re likely to get a “contribution” to a new one if it can’t be repaired, not a straight replacement machine in most cases. Of course that depends on the policy but for most this will apply after the initial five years is up.
    K. Ok thanks, I will pursue a repair. Do you think it could be the fan that supplies the cold air from the freezer to the fridge or do you have any ideas on what could be at fault?
    #223557
    leginjc
    OK I have at last got the repair completed and as I suspected it was the fan!!!! So with all the parts that Hotpoint have changed I hope this will give a few more years service.
    #223558
    maltheviking
    leginjc wrote:OK I have at last got the repair completed and as I suspected it was the fan!!!! So with all the parts that Hotpoint have changed I hope this will give a few more years service.
    😀Sadly it is easy for them to throw parts at the appliance it’s the easiest way for some of thes guys to get through their work load in a day and possibly overcome their lack of skills. 🙁 Hope your unit gives you years of satisfaction
