I have a frost-free Hotpoint FFA52 which I inherited with my previous house, and it worked fine for 10 years. Since I moved however, for some reason the freezer compartment has started icing up. I noticed the removal guys didn’t leave it quite level, so I’ve corrected that, and defrosted it, but I can see the problem hasn’t gone away. There is a sort of covered shaft at the back of the compartment, and you can see solid ice forming at the bottom where water has entered through it, which then starts backing up and getting into the drawers. Wondering if anyone might know what the problem is? I’m mystified as to where the water is coming from or how it’s getting in.
