Re: hotpoint ffa60
indespoint wrote:Hi check duct in freezer is not blocked with ice. If thats ok change PCB. Thermistor in freezer is not replacable
😕 Hi indespoint i have a question. When you say the thermistor is not replaceble is it because it is moulded in and what if it IS faulty, changing the board won’t cure the fault will it? I’m only curious to learn because i’ve come accross faults with F/freezers with moulded in ntc’s (proline and ocean) and changed the board with no joy and basicly its a throw away job.
