Hotpoint FFA60 drain frozen solid
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint FFA60 drain frozen solid
  • #16340
    Seamy
    Been to look at a Hotpoint F/Freezer FFA60P, frost free type, found the drain gutter from fridge to be blocked, tried the usual pushing a ty-wrap through it & pressure switch hose, up from behind, no joy seems to be frozen solid 6-7 inches down from fridge. Tried pouring hot water down & waited but alas no joy, as it was quitting time i told her i would return today & i will get de-icer & try. Anyone know if this is likely to be a problem with defrost heater in freezer, is there a gutter heater to assist defrosting?
    #169406
    Dave_Conway
    Re: Hotpoint FFA60 drain frozen solid
    Just the single defrost heater Seamy.
    This thread may help though:
    http://www.ukwhitegoods.co.uk/modules.p … ic&t=12606
    #169407
    maltheviking
    Been to one of these today with a similar fault, in the fridge section there is a build up of ice 2-3 inches to the left of the gutter drain hole (drain is clear 😕 ) and customer is comlaining that food is freezing in the crisper boxs, she says that this has been ongoing virtualy from when she bought it. 😕
    Before I read this thread my first thoughts was that some of the internal pipes may be to close to the liner and/or poor insulation in that area, obviously there is no way to investigate this. 😥
    My question is would the previous comments about the problem fan area etc. give the problem that I am describing?
    #169408
    hotpnt
    hi, did you resolve this one?,
