HOTPOINT FFA70P
S/N 28100140
*This machine has a cooling plate in the fridge and does not blow any air from the freezer.
Two LED’s are lit on the control panel (above fridge door)indicating error… HIGH TEMPERATURE LED LIT + FOOD DEFROST LED LIT
The freezer air circulation fan is running almost constantly, it does briefly switch off for a second or two, but will be switched straight back on again.
The compressor will turn on for about 10 seconds, it does this periodically every 5-10 minutes, but mostly the compressor is off.
Any help would be greatly appriciated here, i suspect the PCB, but i am also aware the comp. might be the problem, it just keeps cutting out.
Many thanks
