HOTPOINT FFA74G
  • #47235
    kevinlewis
    HEY GUYS WONDERING IF YOU CAN HELP
    FRIDGE OVERCOOLING
    FREEZER NOT COOLING AT ALL
    IVE TESTED:
    SENSORS TESTED OK IN SERVICE MODE
    PCB SHOWS NO VISIBLE DAMAGE
    DIVERTER COIL CONTINUITY OK
    ANYIDEAS?
    THANKS
    #292777
    johnnyj
    Re: HOTPOINT FFA74G
    System fault by the sound of it, they are prone to leaks from the anticondensation loop around the freezer door. jj
    #292778
    kevinlewis
    CUSTOMER NOW SAYS FRIDGE GONE OFF, SO IT SEEMS YOU’R CORRECT THERE IS A LEAK.IS THE CONDENSATION COIL REPAIRABLE OR IS THERE A MODIFICATION?,
    #292779
    johnnyj
    Re: HOTPOINT FFA74G
    You can bypass it but more than likely a call back with a complaint of condesation around the freezer.
