Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Hotpoint FFA90S Problem – leaked last night
- This topic has 6 replies, 4 voices, and was last updated 19 years, 1 month ago by
whistler.
February 23, 2007 at 9:36 am #25304
whistler
ParticipantHi – Last night it started to drip water from the bottom left hand side – not much, just a few tablespoons. I wiped it up and it stopped, but I couldn’t find any wetness around the seals or anything. I waited a couple of hours and the temprature seemed OK so I had a look inside and under the bottom drawer there is a thick sheet of ice (solid – not like frost). I wonder if maybe a bit of the was caught in the seal and melted. Anyway, Hotpoint wanted a £90 call out charge. Any ideas how this might be solved without an engineer? Thanks.
February 23, 2007 at 11:19 am #205291Dave_Conway
ParticipantRe: Hotpoint FFA90S Problem – leaked last night
Try a total defrost for 48 hours to get rid of the ice, it may have been a one off 🙂
If it recurs, an engineer is the answer with these as they are electronically controlled and hard to pinpoint the problem without testing quite a few components.
February 26, 2007 at 8:15 pm #205292Tenfx
Hello
I have the same freezer, with the same ice build up problem.
Thick ice at the bottom of the freezer section.
These are frost free models, do you still need to defrost them from time to time?
Did defrosting sort your problem?
T
February 27, 2007 at 9:20 am #205293whistler
Hi – I am going to defrost it at the weekend – I had too much stuff in it to do it this week. (Thanks for your reply, Dave).
However, saying that, it happened again last night and I had a close look and the water is in fact not coming from inside the freezer chamber but from the join right at the bottom left hand corner of the fridge where the corner joins together and there is a gap. I can hear a dripping from somewhere inside. 😕
March 2, 2007 at 8:33 am #205294whistler
I defrosted the freezer last night and when wiping it round I found a hole in the white lining about 1cm square towards the top where the second basket slots in. Would this account for the water running out of the bottom (assume that there is ice building up on the inside wall outside of the white lining, melting and running out the bottom)? If so is it repairable or am a looking at a new fridge freezer? Also is it dangerous?
March 3, 2007 at 1:15 am #205295Penguin45
Once water freezes in the insulation, I’m afraid it’s doomed. It will drive the temperature sensors out of range, so the machine will start to misbehave and you can never, ever get the water out of the foam.
Sorry,
Penguin45.March 5, 2007 at 9:34 am #205296whistler
Hi – thanks Penguin 45. I had a local independent engineer out on Friday and he cleaned out the drainage thingy – he said it was backing up. He didn’t think the small hole would necessarily affect the running but that now he had done the cleaning out, but only time would tell. He thought the water was running out the bottom because of the blockage. So bearing your advice in mind, I suppose the course of action for me is wait and see rather than dash out and buy a new freezer. he also suggested that if it did continue to misbehave, I should call out a hotpoint engineer because the parts are guaranteed for five years and I shouldn’t expect the lining to be damaged through normal use.
