Hi, how do you get to the fan ? it makes a high pitched metalic noise when it first starts up then after a few seconds you can hear it blowing normally, I think it needs a bit of oil on the bearings ?
Otherwise the freezer is fine and the fridge drain blocks occasionally leading to ice under the salad drawers.
