Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint First Addition WMA20 = Problems
- This topic has 13 replies, 3 voices, and was last updated 19 years, 11 months ago by
mrmister.
May 14, 2006 at 10:36 pm #17809
mrmister
ParticipantHi
I have a hotpoint first addition WMA20 bought it 13 months ago and as expected just after the warrenty ran out it started going wrong,the main problem is when running through a program it will go almost all the way through until it gets to the drain , rinse and spin,
it just goes onto end program, leaving the clothing soaking wet, if i try to re set it onto “rinse and fast spin” it begins to refil with water for a second or 2 then clicks back onto end program and the drain motor kicks in,but only for a short period leaving the clothing still soaking ,so i have to keep setting it onto rinse and spin so the drain motor will empty the drum? . then i leave the machine for an hour or so until i can again set it to “rinse fast spin” sometimes then it works , sometimes it just goes straight onto program end and again the drain pump comes on..for a very short time??? 😕 etc etc etcanother problem is sometimes when i set it to wash 60 or 40 i feel the door glass half way through and its hot..next time i do a wash the door is stone cold ? 😕
i probably haven’t explained the problem well enough for anybody to help so im at the stage where it either engineer or skip?
thanks MrmisterMay 14, 2006 at 10:43 pm #176481iadom
ModeratorRe: Hotpoint First Addition WMA20 = Problems
It does sound as though you may have a partial pump blockage or sump obstruction, If you do not feel capable of checking this yourself then click on the link in my sig to see if we have someone who can help. It should not be over expensive if this is the cause of your problem.
Please remove the mains plug if you intend to open the patient up yourself.
As regards your reference to the ‘skip’ please bear in mind that you do have a five year parts gaurantee on this machine, even if the machine suffered a major expensive failure you would only have to pay the Indesit Co’s £90.00 labour charge, you will not be able to go out and purchase a new machine for that price.
Fortunately this machine has the earlier Hotpoint electronics, before Indesit decided to put their own woeful PCB’s into most of the Hotpoint range, also if it is under 2 years old it will have the later bearing seals which have virtually eliminated the large number of bearing failures on these.
In short, get it seen to. 🙂May 14, 2006 at 10:43 pm #176482Penguin45
ParticipantRe: Hotpoint First Addition WMA20 = Problems
Not the worlds finest washer I’m afraid. Right, when it faults to “end”, do you get any of the progress or option lights flashing at the same time? If yes, they may identify a fault code which would help us enormously. As to the heat issue, can’t offer anything at this stage.
Penguin45.May 14, 2006 at 10:48 pm #176483mrmister
ParticipantIt does sound as though you may have a partial pump blockage or sump obstruction, If you do not feel capable of checking this yourself then click on the link in my sig to see if we have someone who can help. It should not be over expensive if this is the cause of your problem.
thanks iadom
if i knew where the sump or pump was i may be able to check it , how would i get to them if i decided to have a go myself? any ideasMay 14, 2006 at 10:49 pm #176484mrmister
Participantthanks Penguin45
no codes or flashing lights on this hunk of junk im afraid.. very basic model ?
May 14, 2006 at 10:53 pm #176485Penguin45
Pump – at lowest point of machine.
Sump hose – connects drum to pump and contains filter.
Remove plug and rear access panel to reveal all.Evening Iadom……. :wave:
May 14, 2006 at 10:56 pm #176486mrmister
Participantiadom & Penguin45.
your stars..ill give it a go tomorrow and see what i find..if not ill give you an update
thanks for your advice and timeregards mrmister
May 14, 2006 at 10:57 pm #176487iadom
Tsk, tsk. If it does turn out to be a pump obstruction or similar it is worth noting that in 99{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of cases this is due to user misuse, not due to the quality of the machine.
The pump is behind the lower back panel, arm yourself with a couple of towels and a washing up bowl or large roasting tray. Power off at all times.
May 14, 2006 at 11:00 pm #176488iadom
Evening P45, looks like the weather may save Sri Lanka 😉
mrmister, please take note of my earlier post, if the worst comes to the worst, you have a full five year parts warranty.
May 14, 2006 at 11:02 pm #176489mrmister
Participantwas told it wasnt the best of washers…Hmmmmm without a doubt it will be down to me im sure , lets hope i can sort it without a lot of fuss and expense.
ill be armed with towels and washing up bowl
thanks again
mrmisterMay 14, 2006 at 11:03 pm #176490mrmister
Participantsure its worth paying the £90 if i cant sort it
cheers all
goodnightMay 14, 2006 at 11:09 pm #176491iadom
Moderatormrmister wrote:sure its worth paying the £90 if i cant sort it
cheers all
goodnightDon’t be silly, even allowing for the Italian and Chinese degradation of the domestic appliance market BISE, you will not be able to buy another machine for £90.00.
The machine you have, although basic is not one of the worst machines on the market, it does not have the dodgy Indesit controls and it has the later drum bearings. It should last you for a few years yet.
NB. BISE= Before ISE 😉May 15, 2006 at 12:15 pm #176492mrmister
Penguin45 wrote:Pump – at lowest point of machine.
i did everything you sugested and BINGO 😀
Not only is my washing machine working like brand new but after emptying the sump hose and pump im £1.57p.. 2 drawing pins..a button and some elastic better off…lolA big thankyou to iadom and Penguine45..you are complete stars and have saved me £90.. 😆
Best regards MrmisterMay 15, 2006 at 3:47 pm #176493iadom
Best regards MrmisterYou see, its not such a heap of junk after all, you just need to educate the operator now, 😉
Coins can do very serious damage to modern machines with nylon outer drums, you have escaped this time.
Thanks for letting us know the outcome.
