hotpoint first edition (few10) door lock need help plz
Home Forums Public Support Forums Help And Support Washing Machine Help Forum hotpoint first edition (few10) door lock need help plz
  • #41840
    hotpoint-problem
    Hi i have a hotpoint few10 washing machine the door lock light was flashing and the washer would not start the only way to start the washer was to hold something against the door for the light to stop flashing but this does not work know
    so i took the door lock off and bought a replacement off internet and i have put this on and it does the same flashing light door and wont lock
    my question is the part i bought is not the same as the original but was told this was a direct replacement the part number is DA066 the old part number is ZV-446 METAFLEX
    any help please
    #271509
    Re: hotpoint first edition (few10) door lock need help plz
    Could be a broken spring inside the door assy. The door can be removed via the hinge and split in two to check spring.
    Simon46
    was the original red and the new white? if so the plug requires turning the other way round. Unplug before checking.
    S.
    #271511
    hotpoint-problem
    hi yes i did this with the plug turned it around still no joy
    is the spring in the handle on the door ?
    #271512
    hotpoint-problem
    hi colour is black and burgundy and the new part is white/cream and larger in size
    #271513
    iadom wrote: split in two to check spring.
    I thought that was a fairly accurate description of how the spring can be located , 😉 😆
    Take out the two screws holding the hinge and then remove the screws around the door and prise it open with a thin bladed screwdriver.
    Colours are correct for latest door lock, plug has to be reversed.
    helo_75
    i once put the plug on one wrong
    just you hope what happened to me happens to you!
    #271515
    hotpoint-problem
    thanks for the repies will check out the spring and keep you posted
    thanks
    #271516
    hotpoint-problem
    i have checked the door and spring is ok not broken
    after all this i have just been informed by my other half that when the washer was working there was a bang ??
    so i have just removed the front panel of the washer and there is black marks on the board looks like something has gone bang (behind the door programme switch)
    so i think this will be reason for the flashing lights?
    i have heard that hotpoint do a 5 years parts replacement would the circuit board be included?
    thanks for all the answers and sorry for not explaining the cause of this problem thats women for you
    #271517
    All parts are covered for five years, the labour will cost you a fraction under £100.00 though. 😥
    The door lock will have blown the module.
    hotpoint-problem
    thanks jim for the reply
