Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint First edition WMA13
- This topic has 8 replies, 4 voices, and was last updated 12 years, 5 months ago by
ianswing.
November 10, 2013 at 1:10 pm #78027
ianswing
Participanthad enough of the deafening noise when the washers on spin :eeek: just been reading up on the nightmare job in prospect,now the page on replacing bearings is rather vague in regards to some been relatively easy and some been a pain, anyone help on this model please, is this one of the easier ones 😀
Oh, and is there any other parts I should replace while im busy carving chunks out of my hand on the various sharp edges :rolls:November 10, 2013 at 1:56 pm #404234Martin
ParticipantRe: Hotpoint First edition WMA13
The outlook is challenging for you to put it mildly. The bearing kit is cheap to buy though if the bearings have collapsed then you will need a new drum support shaft as well. Add to the list the two halves drum gasket, a box of Band Aids and have the phone handy in case you have to dial a 3 digit number. 😉
November 10, 2013 at 1:59 pm #404235iadom
ModeratorRe: Hotpoint First edition WMA13
TBH if it has been noisy for some time you will almost certainly need a new drum rear and drum support.
It could have the proper Hotpoint bearings or the cheaper 30mm ones fitted by Indesit.
November 10, 2013 at 2:23 pm #404236Andy jones
I would hardly ever fit bearings without fitting a new spider as well, pig of a job if you haven’t done one before
Sent from my iPad using Tapatalk HDNovember 10, 2013 at 2:26 pm #404237iadom
Don’t bother ordering any parts until you have attempted to strip it down first.
November 10, 2013 at 2:27 pm #404238ianswing
Thanks for the quick replies, I’d looked at the new drum rear,didn’t realise there’s a drum support to price up also,i take it there’s a seal between both sections of the drum ? and the door seal at the same time ? new suspension and it’ll be good as new,if it doesn’t end up in the garden in 2 million bits 🙂
November 10, 2013 at 2:30 pm #404239ianswing
iadom wrote:Don’t bother ordering any parts until you have attempted to strip it down first.
Thanks for the advice,will have to try get it in bits and see whats what ❓
November 10, 2013 at 8:11 pm #404240iadom
Remember that this machine could have either 30mm or 35mm bearings and shaft. 😉
November 10, 2013 at 9:10 pm #404241ianswing
iadom wrote:Remember that this machine could have either 30mm or 35mm bearings and shaft. 😉
😀 thanks for that,going to attempt to strip it down 1st and if I manage that I’ll start looking what parts to replace at the same time,watch this space :rtfm: :haier:
