Hello, I called out to this one yesterday, the machine starts as normal runs for approx two minutes then you can hear the door lock disengage and it all stops, if you press start it will run for another two minutes then click and stop.
Having changed the door lock I presume it is going to be a fault on the module anyone else had this?
