Hi gent reading fault code on this machine ( top wash noen flashing and door lock noen on code only give you the 54321 5 being rinse 1 being door key this is then 6 wash neon flashing can anyone help) on fault please cheers alro
The instructions in the known error codes thread are quite straightforward. It says The BOTTOM FIVE lights are the only ones used for error codes. The error codes indicators DO NOT flash although several other lights may be flashing. So sadly you have F01. 🙁
