Hotpoint Forno SHS 33x oven thermostat light
Home Forums Public Support Forums Help And Support Cooker And Oven Forum Hotpoint Forno SHS 33x oven thermostat light
  • #93268
    wig_1
    Hi, can anyone help please?
    I have Hotpoint Forno SHS 33x oven. The thermostat light has been pushed through by a small child, leaving a hole in the control panel.
    Does anyone know how to remove the control panel to gain access to the light to put back in place? I have removed 2 screws underneath the control panel but it won’t budge… thanks
    #453752
    Re: Hotpoint Forno SHS 33x oven thermostat light
    getting into these panels can be a challenge. a lot of the time you have to remove the top to get in
    As for the lamp you child has not pushed it in as that is not possible. there is an outer lens that goes into the hold from the front
    https://shop.ukwhitegoods.co.uk/c002681 … -lamp-lens
    and then the lamp unit clips on the back of this and holds it in place
    https://shop.ukwhitegoods.co.uk/c000280 … ignal-lamp
    wig_1
    Thanks Dave,
    That seems logical, so my best bet would be to lift the hob off to gain access then? Thanks for the reply
    Mark
    #453754
    sorry answered without checking
    this is a single oven
    there should be screws round the door holding it into the unit
    undo screws and pull oven out and remove top after disconnecting from supply
    wig_1
    Thanks for the reply, will try this and get back to you today. Mark
    #453756
    wig_1
    Yes, removed the screws around the door, pulled the oven out enough which revealed side screws which held the control panel in place. This gave access to the light! Now going to order lens cover. Many thanks Dave
    #453757
    check the lamp assembly inside look ok as they break with the heat over time.
    wig_1
    yes you are right, the lamp clip was broken!! thanks again
