Hotpoint fridge/freezer FFA52
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint fridge/freezer FFA52
  • #48094
    kgldsun
    Can anybody confirm the following for me please? The above item has a ‘wet body/walled fridge(as per my repair engineer) which is why I am experiencing a large amount of what is described as condensation. My fridge/freezer is 5 weeks old. Constantly on the glass shelves my food is sat in ‘puddles’ of water. The tops of jars and yoghurts etc also has small puddles of water on them. Cardboard packaging is reduced to a damp mess.
    I am really so upset and even more so today when ‘Hotpoint’ repairs came out and basically told me ‘tough’ as that is the way this type of FF performs.
    Please can anybody confirm or unconfirm this for me? Many Thanks. 😡
    #295555
    Re: Hotpoint fridge/freezer FFA52
    There shouldn’t be condensation on the shelves, full stop.
    The only ways that can happen, that I can think on is through either air ingress (hot air getting in) or a large quantity of fresh has been put in at one time that’s caused a temperature rise or it’s “sweating”.
    I can’t see it being made to make your food wet though.
    kgldsun
    Thanks for your reply. I have a technician coming out to see the fridge in 10 days as I am going away. I had to demand to see one, as Hotpoint insist it is ‘normal’. I will though not accept it and like you say my food should not be wet to the degree it is.
    I have a good seal all around the door and it has been a problem since day one which tells me its not the food that is in the fridge either.
    Thanks once again and hopefully I will be able to report a success on my return!
    #295557
    spimps
    Any shelves touching the wet wall?they shouldn’t be!
    Condensation on the wet wall is fine but it shouldn’t be getting onto the shelves.
    BG
    #295558
    shoulders
    Hi, check that no food is touching the back wall. when the machine defrosts itself, the water will drain down the food instead of the wall, thus soaking everything.
    alternatively, check that the shelves have their protective ‘lip’ to the rear of the shelf pointing up. this is designed to stop things touching the back wall.
    alternatively, you may have an inefficient compressor, hotpoint have fitted lots of these, but will not admit it. does the back wall ever actually have frost on it? IT SHOULD HAVE but only about 25{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time. by design, they freeze/ melt/ freeze/ melt etc.
    dont take any crap from hotpoint, i’ve been fixing fridges for 20 years and some of the rubbish i’ve heard from their engineers defies all belief. you should NEVER have water on the shelves (but be really sure you haven’t stocked it up wrong or you’re gonna look really stooopid.
    good luck
    #295559
    shoulders
    oh, also check the interior light goes out when the door shuts (by pulling back the door seal a little as you open and close the door)
    #295560
    cameraman
    and dont forget this so called hotpoint is really made by beko
    #295561
    helo_75
    how constructive and helpfull that was
