Hotpoint Fridge Freezer Flashing
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Fridge Freezer Flashing
  • #58881
    subs
    FF187E
    Got called out to this frost free, fault warm fridge. I found ice build up due to blocked evaporator drain hole. There was no ice around evaporator or heater so assume defrost was working. Checked heater/ thermal cut out etc all ok. Cleared all the ice and switched back on. I noticed the super cool and super freeze (i think) lights flashing which i thought would stop once down to temp. This was 3 weeks ago and i just got a call to say although the FF is working fine the lights are still flashing.
    Anyone know what this could be?
    The only thing i can think is (although i was carefull not to) i blew the thermal cut out with my steamer and its flashing a fault for open circuit cut out.
    Any ideas?
    Subs
    #336006
    johnnyj
    Re: Hotpoint Fridge Freezer Flashing
    Switch the 2 control knobs to the off position then sw them back on usualy clears it, jj
    #336007
    subs
    Thanks JJ! I’ll give it a go!
    Subs
