Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Hotpoint fridge/freezer handle fitting?
- This topic has 16 replies, 4 voices, and was last updated 11 years ago by
oldcelt.
April 10, 2015 at 11:13 am #84670
oldcelt
ParticipantJust taken delivery of new fridge freezer, model FFLAA58WDG and the handles are supplied unattached. No instructions given for fitting. Help please?
April 10, 2015 at 11:42 am #426424don
ModeratorRe: Hotpoint fridge/freezer handle fitting?
Handles are sometimes packed separately so they don’t get damaged.
The screws for the handles are either fitted to the door edge or they are in the instruction pack. If the handles have two screw holes on one end these go to the top.
I would have thought this would be covered in the instruction manual 😉
DonApril 10, 2015 at 11:55 am #426425oldcelt
ParticipantRe: Hotpoint fridge/freezer handle fitting?
OK, solved it. The covers for the fixings are just clipped in place – quite difficult to get off but that’s how it’s done. And, no, the manual doesn’t cover it!
April 10, 2015 at 11:57 am #426426don
Glad you sorted it :tup:
May 20, 2015 at 10:35 am #426427lukep1990
I got this problem! How did you do it?!
May 20, 2015 at 10:46 am #426428don
Which make and model fridge freezer do you have?
DonMay 20, 2015 at 10:48 am #426429lukep1990
Hey, its the same as the one first posted, the FFLAA58WDG. thanks!
May 20, 2015 at 11:00 am #426430don
The answer you are seeking is in the above posts 😉
DonMay 20, 2015 at 11:01 am #426431lukep1990
Its just a bit vague, can’t work out what clips where. I don’t wanna break anything aha
May 20, 2015 at 12:03 pm #426432don
The clips refereed to above are the little circular white cover caps covering the screw holes on the left hand door edge. These will simply pop out with a flat blade.
HTH
DonMay 20, 2015 at 12:04 pm #426433lukep1990
ParticipantMay 20, 2015 at 12:14 pm #426434don
Picture is too small to work out what it is.
Can you repost the picture using the upload attachment button which is just under the preview and submit post butons please.
May 20, 2015 at 12:16 pm #426435lukep1990
You can click it and it will make it bigger I believe 🙂
May 20, 2015 at 12:39 pm #426436don
Managed to download a bigger pic from Image Shack.
The two halves of the fixing come apart with a small flat blade into the little recesses and gently easing the two halves apart.Don
May 20, 2015 at 1:27 pm #426437lukep1990
Awesome! Thank you sooo much!!
