Hotpoint fridge/freezer handle fitting?
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint fridge/freezer handle fitting?
Viewing 15 posts - 1 through 15 (of 17 total)
  • #84670
    oldcelt
    Just taken delivery of new fridge freezer, model FFLAA58WDG and the handles are supplied unattached. No instructions given for fitting. Help please?
    #426424
    don
    Re: Hotpoint fridge/freezer handle fitting?
    Handles are sometimes packed separately so they don’t get damaged.
    The screws for the handles are either fitted to the door edge or they are in the instruction pack. If the handles have two screw holes on one end these go to the top.
    I would have thought this would be covered in the instruction manual 😉
    Don
    #426425
    oldcelt
    OK, solved it. The covers for the fixings are just clipped in place – quite difficult to get off but that’s how it’s done. And, no, the manual doesn’t cover it!
    #426426
    don
    Glad you sorted it :tup:
    #426427
    lukep1990
    I got this problem! How did you do it?!
    #426428
    don
    Which make and model fridge freezer do you have?
    Don
    #426429
    lukep1990
    Hey, its the same as the one first posted, the FFLAA58WDG. thanks!
    #426430
    don
    The answer you are seeking is in the above posts 😉
    Don
    #426431
    lukep1990
    Its just a bit vague, can’t work out what clips where. I don’t wanna break anything aha
    #426432
    don
    The clips refereed to above are the little circular white cover caps covering the screw holes on the left hand door edge. These will simply pop out with a flat blade.
    HTH
    Don
    #426433
    lukep1990
    And on the fridge is just screw, nothing else.
    #426434
    don
    Picture is too small to work out what it is.
    Can you repost the picture using the upload attachment button which is just under the preview and submit post butons please.
    #426435
    lukep1990
    You can click it and it will make it bigger I believe 🙂
    #426436
    don
    Managed to download a bigger pic from Image Shack.
    The two halves of the fixing come apart with a small flat blade into the little recesses and gently easing the two halves apart.
    Don
    #426437
    lukep1990
    Awesome! Thank you sooo much!!
