Hotpoint fridge/freezer Mod. FF187E
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint fridge/freezer Mod. FF187E
  • #57093
    Ashby
    Hi, The freezer is working fine on this one ,but the fridge is not getting cold at all?
    Any suggestions please?
    many thanks.
    Ashby
    #329786
    Re: Hotpoint fridge/freezer Mod. FF187E
    frozen up evaproator in Freezer at a guess. take the cover off inside the freezer and have a look. sensors not replaceable on this one so test the heater and thermal fuse, if they are ok then it will be pcb. early ones are fitted to rear, later ones are in the top panel. both will need the smart card reader to programme, if the pcb is in the top it will also need the 2007 low end adaptor to programme it.
    could be worth a shot at defrosting it and see how it goes.
    if it is not frozen up then check the baffle in the fridge, could be jammed.
    #329787
    Ashby
    Many thanks for your help. Will try that.
    Ashby.
