Hotpoint fridge HS3022VL door seal split
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint fridge HS3022VL door seal split
  • #91464
    Simonhamersley
    How is the door seal removed on this model. It seems to be firmly clamped in place by the internal part of the door and the outer. I can find no indication of how to separate the door to remove the seal. Is it a case of brute force to remove it? Or is there a better way? Hotpoint less than helpful, said they couldn’t advise due to Health and Safety!!!
    Advice greatly appreciated
    #448215
    Re: Hotpoint fridge HS3022VL door seal split
    can you get a seal?
    some fridges are complete doors only
    Never seen one let alone done one but the seal part number is C00268667 and it’s a special order everywhere, nil stock completely.
    Blowout is all we have…
    Simonhamersley
    Yes, I have the new seal. Fyi got from Partmaster.co.uk
    #448218
    Ask them then. 😉
    Simonhamersley
    They say they do not give fitting instructions but encourage diy!!! They are part of the Currys/PCWorld group so I wasn’t expecting much. Do you know who could advise?
    #448220
    looking at the new seal how does it seem to clip on ?
    had one seal that you had to cut the old seal off, then after you cut it off there was a plastic channel to clip the new one into
