Hotpoint Frost Free Fridge/Freezer Mod.8590
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Hotpoint Frost Free Fridge/Freezer Mod.8590
  • #13834
    Ashby
    Hi, This Fridge/Freezer will work fine for a while, then cut off even power to the interior light. I’ve noticed that there’s a defrost timer next to the stat. would it be this that’s causing the problem?
    Thankful for any help with this problem.
    Ashby
    #156880
    Dave_Conway
    Re: Hotpoint Frost Free Fridge/Freezer Mod.8590
    Has the customer or someone been “playing” with this by any chance and messed with the wiring ?
    It sounds like the timer is not only switching the compressor off but everything else as well. How long are the intervals between the shut downs ?
    #156881
    Ashby
    Hi Dave, I’m told it shuts down for quite a while an hour or so maybe more? The customer has just moved into this house and inherited the Fridge/Freezer. Do u have a wiring diagram u could e-mail to me?
    Thanks for your help.
    Ashby
    #156882
    mike412
    I HAVE THE 38 PAGE MANUAL ON THIS MODEL, CAN FAX RELEVANT PAGES IF YOU PM DETAILS.
    MIKE
    #156883
    Dave_Conway
    There you go 🙂
    I was more concerned about the length of time between the stops rather than the lenth of time it went off for. Defrost cycles are approx 8-16 hours. The manual Mike has should tell you 😉
    #156884
    Ashby
    Hi, Still having problems with this Fridge/Freezer. I’ve changed the thermal cut out and it’s now running ok. but the customer says it’s now not getting cold enough. I’d be thankful for any ideas.
    Ashby 🙁
    #156885
    Dave_Conway
    Have you checked all the defrost functions etc (the usual problems) Ashby ?
    Loads of ice building up I would think 😉
    #156886
    mike412
    Defrost Heaters?.
    Mike.
