Home › Forums › Public Support Forums › Help And Support › Dishwasher Help Forum › Hotpoint FSW20 not draining after wash.
- This topic has 6 replies, 2 voices, and was last updated 14 years, 8 months ago by
dave83.
July 24, 2011 at 5:01 pm #64120
dave83
ParticipantHello
Any help is most appreciated. My Hotpoint dishwasher has stopped working. After the wash cycle it stops and the prewash and wash lights flash. I read that the drain pump maybe blocked, i has since stripped out and check but no blockages. I was thinking it is now either the pump is knackered or it is not getting a supply to start.
Is there any way i can check or test the pump ?Many thanks David
July 24, 2011 at 6:15 pm #356150iadom
ModeratorRe: Hotpoint FSW20 not draining after wash.
Can you double check that model number please.
July 25, 2011 at 8:56 pm #356151dave83
ParticipantRe: Hotpoint FDW20 not draining after wash.
iadom wrote:Can you double check that model number please.
Hello
Oh sorry the model number was wrong it is a FDW20. I have edited the post title.
Thanks David
July 25, 2011 at 10:05 pm #356152iadom
Does it actually fail to drain?
Does the main circulation pump appear to be running, are the spray arms going round at the start of a programme?
The pumps don’t often fail electrically but do become worn if well used. A continuity/resistance test with a megger or multimeter would show if the motor was electrically faulty.
Can you hear the drain pump trying to run at the start of any cycle before the machine fills?
If it stays full of water have you tried leaving it for a few hours and then trying to get it to drain?
If your serial number is 60222.0001 or higher then the drain pump is wired in series with the main circulation pump, a failure of the main pump motor will prevent the drain pump from running.
July 26, 2011 at 9:53 am #356153dave83
ParticipantRe: Hotpoint FSW20 not draining after wash.
Hello
Thanks for the reply. Yes it fails to drain and yes the main circulation pump is running. No i dont hear it running at the start of each cycle. I left it over night and tried it again without a wash tablet but it still fails to drain. The 1st and 2nd lights flash together and when you open the door there is a inch of water sitting in the base.
Thanks David
July 26, 2011 at 10:07 am #356154iadom
It really is time for the test equipment, first on the pump itself and then the wiring.
July 27, 2011 at 8:11 pm #356155dave83
iadom wrote:It really is time for the test equipment, first on the pump itself and then the wiring.
HelloQuick update, striped the pump out again and put 240v on to it and it ran no problems but after turning off and on again the pump stalled. After opening it up further i found the o rings on the inside had been passing and behind it was all gunged up. So cleaned and replaced o rings rebuilt and job done. Thanks for your help.
David
