Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint hfc2b 19x uk error code
- This topic has 5 replies, 2 voices, and was last updated 2 years, 9 months ago by
slyp98.
July 4, 2023 at 11:47 am #102070
slyp98
ParticipantHi all, this dishwasher is flashing 1st and 3rd led , I take it they are horizontal left to right 1 to 5
any tech info in these thanks kJuly 4, 2023 at 10:42 pm #487422Hollytree_Technical
ParticipantI think that this would be Error 5 – “Pressure Switch Non Compliant”, In every case that I have had this error it has been caused by gunge in the air trap and I have usually had to put a couple of litres of water into the machine and then fire water down the pressure tube from the switch end to clear it.
I have got some service manuals saved for a HEFC2B19CUK which I think is a very similar machine if you need them.
Jem
July 5, 2023 at 9:02 am #487423slyp98
ParticipantHi Jem, I tried that and I activated the pressure switch manually, still error on it
I’m thinking it may be the inlet turbine not registering water flow but again not sure thanks kieranJuly 5, 2023 at 9:03 am #487424slyp98
ParticipantHollytree_Technical wrote:I think that this would be Error 5 – “Pressure Switch Non Compliant”, In every case that I have had this error it has been caused by gunge in the air trap and I have usually had to put a couple of litres of water into the machine and then fire water down the pressure tube from the switch end to clear it.
Jem
I’d like that service manual if you could email it , I’ll pm you thanks k
July 5, 2023 at 10:51 pm #487425Hollytree_Technical
ParticipantSometimes I will have to pull and push the water (note: don’t bother using air as it doesn’t seem to have enough power) quite fast through the pressure trap to get it to shift the gunge but you will usually see the gunge floating into the sump fairly quickly.
The pressure switch has to be activated by the time the machine has come to the end of the static fill (2.5L of water), if there is gunge in the trap then it may test out okay when you fill it manually but it is too slow to react in time when the machine does it which will cause the error to be thrown (guess who bought a board one day because they didn’t realise this was what was happening
).Anyway i have emailed you the service manual plus a load of other documents that I had saved against that model no.
Jem
July 6, 2023 at 11:46 am #487426slyp98
ParticipantThanks for the help Jem
