Hotpoint hm325ff.1 – Freezer good. Fridge warm
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint hm325ff.1 – Freezer good. Fridge warm
  • #89796
    andrewjb
    So… as the title. The (lower) freezer seems to get cold enough (-25 when on ‘full’) but the fridge stays warm.
    Fully defrosted (left off for several days). Fan is running fine.
    I can’t see how the cold air is circulated into or around the fridge section? Anyone know? There doesn’t seem to be any duct/channel for it to get up there..
    And is the fan supposed to run continuously, because it does.
    #442575
    Pdajohn
    Re: Hotpoint hm325ff.1 – Freezer good. Fridge warm
    Hello
    Did you fix your fridge problem
    #442576
    Pdajohn
    Hello
    Did you fix your fridge as i have the same problem
    #442577
    andrewjb
    Basically… no. The radiator on the back wasn’t very hot – I decided it was almost certainly the compressor that had gone, and wasn’t worth replacing. So new fridge was purchased… 🙁
