hotpoint hob 6343p
  • #59615
    hilly
    s/no 70000733 one of the small 1200w plates needed replacing the replacement i recieved was p/no c00228944 but when i fitted it it comes onto full power even tho the regulator is off? i swapped the other original good plate and that works ok, have i got the wrong part or is there a modification for this?
    many thanks paul
    #338895
    Re: hotpoint hob 6343p
    Listed as correct part,no mods mentioned. 😕
    #338896
    AFAIK all ceramic rings have wiring mods. The old connectors for the hob hot light and the safety stat have changed positons. Need to be very careful when wiring these. Dont just wire by position of tag. you have a pair normally closed across the safety and a pair normally open across the hob hot light swtich. Best to identify these with a meter first. Usually you do get a bit of paper with the rings explaining this.
    #338897
    Sorry, I meant no mods mentioned on Partfinder.
    As Marks says most of these units have been altered and until recently always came with a wiring diagram.
    Sadly the last two or three I have had did not contain it. possibly a deliberate action by Merloni.
    …and they can be a right pain when the leads dont reach! file under unnesesary modifications just to confuse us, along with changing the markings on energy regulators. 🙂
    #338899
    hilly
    Cheers for the replies, I’ll go and have a play with it! As there was no leaflet with it I assumed it would be like for like but guess not.
    Cheers paul
    #338900
    Did you get the little something I sent you?
    hilly
    Yes i did
    many thanks
    Paul
