hotpoint hp wd440g – f03 error – whats the ntc resistance?
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries hotpoint hp wd440g – f03 error – whats the ntc resistance?
  • #75049
    gandh1
    Got one of these grumpy grey things.
    Got a resistance value of 3.58 from the dryer ntc and 3.9 from the wash element ntc
    its locked in program F / non-colour 40, and cant clear it to see if it will only run on a cold wash ok. as soon as f03 comes up, it will constant fill, then drain. door locks immediately its closed, without having to press start.
    full model details : 36234/wd440g/58190222, triple coil cold fill and single hot feed, with the top flushing hose (and presumably the gauze strip)
    Didnt have a lot of time to play with the machine as it was a drop-in call, and she had to pick up the kids, so any advice welcome,
    #393701
    jpandjack
    Re: hotpoint hp wd440g – f03 error – whats the ntc resistanc
    ntc wash thermistor 20k @ 20 deg
    ntc dryer thermistor 26k @ 20 deg these will change depending on the temp of the ntc check the wiring and mod connections for continuity failing that change main module
