hotpoint hud61g cooling fan always on
Home Forums Public Support Forums Help And Support Cooker And Oven Forum hotpoint hud61g cooling fan always on
  • #86347
    uksteve23
    My daughter switched on the twin grill and the cooker tripped the fuse.The grill still works fine but the cooling fan is always on. also noticed the switch turns all the way round, not sure if it did that before ( it has four positions to the left and right)
    #430860
    stevebunyan
    Re: hotpoint hud61g cooling fan always on
    It sounds like the cooling fans cycling stat has fused on, It will need to be tested for continuity and should be open circuit when cold.
    Only test once the oven has been isolated from the electrics.
