Hotpoint HULT 943 – door doesn’t open
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Hotpoint HULT 943 – door doesn’t open
Viewing 7 posts - 16 through 22 (of 22 total)
  • #436509
    HerbLeicester
    Re: Hotpoint HULT 943 – door doesn’t open
    iadom wrote:Only you really know the answer to that, not considered a difficult job but if the original wiring plug is burnt you will need to cut off and replace the damaged plug with AMP tags.
    From that serial number the part listed above is correct.
    Thanks! I didn’t realise “kwatt” had already sent a link to the correct part – thanks for that.
    Are there any instructions anywhere for how to access the lock for replacement, or is it obvious somehow, just from looking at the door properly?
    I like your tag line, buy the way, and “kwatt’s” too 8)
    #436510
    No problem, generic instructions are here, they vary a bit from machine to machine but not a lot most of the time…
    http://www.ukwhitegoods.co.uk/help/fix- … -door-lock
    HerbLeicester
    kwatt wrote:No problem, generic instructions are here, they vary a bit from machine to machine but not a lot most of the time…
    Splendid, thanks! I’ll report back in due course.
    #436512
    HerbLeicester
    electrofix wrote:http://www.ukwhitegoods.co.uk/search/find-an-appliance-engineer
    try here
    Thanks – only just saw your reply. I’ll try and do it myself first. Could end in tears, of course 😆
    #436513
    HerbLeicester
    Sorry about the delay in sending feedback – I was away over Easter. Managed to install the new door lock yesterday, with a little moral and practical support from a friend, and everything looked perfectly OK, until the door didn’t open again after the second wash. Unplugged the machine to release the door, started another washing cycle, which seemed to progress OK, but now the dreaded F06 error is back 😮
    Now what? ❓
    #436514
    F06 (F6): –
    Door lock fails to close / open, door lock PTC triac open/ closed, mains frequency signal fault, mains power signal fault.
    – Check for water leaks that may affect connectors J004 or J11
    (three-phase) causing the relative contacts to short;
    – Check Door lock terminal board (any problems due to
    aggression caused by manufacturing chemical residues that may
    cause short circuits);
    – Check J004 / door lock wiring;
    – Check door lock;
    Renew PCB.
    That is the full list, sadly the Indesit electronics in these machines are known to be very flaky and are often taken out by faults elsewhere. 🙁
    #436515
    HerbLeicester
    iadom wrote:F06 (F6): –
    Thanks for your further reply. Looks like I reached the limits of my DIY skills. Time to find a local expert, methinks?
    Based on your feedback re Indesit electronics, I’m not inclined to get another Indesit appliance any time soon!
