Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › hotpoint hv6l105 error
- This topic has 11 replies, 3 voices, and was last updated 12 years, 4 months ago by
shiftypowers.
December 8, 2013 at 11:47 am #78515
shiftypowers
ParticipantHi we have a hotpoint hv6l105 and a few days ago in cycle it decided to stop and all lights across the board came on (not flashing just constant). I turned it off and after a while turned it back on and seemed fine, it did it again yesterday and this time it will not do anything except have all the lights on the control panel constantly on and the water left in. I did think it was blocked and I have found a coin and a nail- what was jamming the ball ( do not ask) what I have taken out but still makes no change. From what I have just read I take it is a component problem somewhere? Thanks for any help
December 8, 2013 at 12:57 pm #405965iadom
ModeratorRe: hotpoint hv6l105 error
Model number incorrect. 😉
When you say ‘ball’ do you mean the eco ball located in the sump hose under the drum?
You make no mention of actually checking the drain pump filter. ❓
December 8, 2013 at 7:16 pm #405966shiftypowers
ParticipantRe: hotpoint hv6l105 error
Hi, Its definetley “HOTPOINT HV6L105.” I have checked the drain pump filter (at the bottom right of the machine and it was clean) and sorry yes the eco ball had the nail half wedged in it.
December 8, 2013 at 7:17 pm #405967shiftypowers
http://www.youreko.com/en-gb/#!/product … nt-hv6l105
heres a link for the model, thanks
December 8, 2013 at 7:22 pm #405968iadom
Ah, HV6l looks different on my screen to HV6L. 😉
How did you get at the hose to remove the nail, did you lie the machine flat or tip it over?
December 8, 2013 at 7:24 pm #405969Martin
This link is better
December 9, 2013 at 6:18 pm #405970shiftypowers
I laid it on its side and then went from underneath.
December 9, 2013 at 6:35 pm #405971iadom
A strong possibility that the pressure switch will need resetting ( at the very least ) 😥 .
All the lights on is not a recognised error code.
December 10, 2013 at 9:06 am #405972shiftypowers
Ok thanks for the advice I take it this is a engineer hotpoint job
December 10, 2013 at 9:24 am #405973iadom
Not the easiest thing to clear, and you may still have an underlying problem.
December 10, 2013 at 10:06 pm #405974shiftypowers
one other thing I didnt mention is that when the washing machine has electricity going to it you cannot switch it on or off on the control panel does that make any difference to problems?
December 10, 2013 at 11:29 pm #405975iadom
Err, how can you not switch it off if you can’t switch it on in the first place??????
The machine is basically 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} Indesit, known for very unreliable electronics, might be time to take advantage of your five year parts guarantee.
