Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Hotpoint HVF344UK
- This topic has 8 replies, 5 voices, and was last updated 14 years, 8 months ago by
silverbroom.
July 26, 2011 at 4:22 pm #64160
silverbroom
ParticipantThis machine requires a set of carbon brushes, having looked around I could not see these listed not even on the Hotpoint site.
Spoke to Hotpoint and told its a motor that is supplied carbons not available for this model. Yes I have tried to adapt from what I have in stock but no joy. Anyone come across this or have a cunning plan.
thanks silverbroom
July 26, 2011 at 4:29 pm #356250washtronics
ParticipantRe: Hotpoint HVF344UK
i think they are the same as a servis brush, try looking at qualtex car99
July 26, 2011 at 4:31 pm #356251electrofix
ModeratorRe: Hotpoint HVF344UK
as you say cant see them listed on connect or qualtex
would have to see a better picture of the holder to see what might fit
can you not find another set and transplant the carbon core
July 26, 2011 at 4:49 pm #356252washtronics
if it is a sole motor then the car99 should fit or hotpoint number C00114885 equivalent
July 26, 2011 at 5:12 pm #356253silverbroom
Thanks for the quick reply, yes have tried other holders etc but no joy. Will check out the other part numbers you gave.
cheers silverbroom
July 29, 2011 at 5:07 pm #356254silverbroom
Just for future ref,if you come across the above machine needing carbons then it is a complete motor job. I carry a good selection of carbons but no joy in swapping outer, inner casings. Thanks for the above advice which I checked out but no joy.
silverbroom
August 15, 2011 at 6:18 pm #356255silverbroom
Up date on this post. Discovered a pair Connect part No CBN9213 fit. Big saving on a new motor.
silverbroomAugust 15, 2011 at 7:10 pm #356256roy1
The dst 50265479001 is sold as a pair it runs in better,and costs only a £1 more.
October 3, 2011 at 5:17 pm #356257iadom
roy1 wrote:The dst 50265479001 is sold as a pair it runs in better,and costs only a £1 more.
These are listed as CESET carbons so will not fit the FHP/AEG type motor unless you do a fair bit of fettling.Was your motor a CESET silverbroom?
