Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Hotpoint HVL 211 Test Mode
- This topic has 8 replies, 3 voices, and was last updated 6 years, 10 months ago by
BWG7919.
May 25, 2019 at 10:15 am #95904
BWG7919
ParticipantHi folks,
I have the above machine which I’ve worked out to have a failing pressure sensing issue (F10). It was a quick visit and I didn’t have time to establish whether it was the sensor or its plumbing, there was a lot of debris whizzing about the drum, most of which I fished out the filter, once I finally managed to unscrew it.I’ve had a look on t’old internet and have a procedure to activate the test mode, this involves selecting mode 1,2 then 3 whilst power cycling the machine with a final anti clockwise turn and then pressing start but until I return this is not confirmed. Does anyone know the correct procedure?
BWG7919
May 25, 2019 at 12:30 pm #461659electrofix
Moderatorthere is an engineering doc that says the pressure hose has a habit of rubbing through on this machine best check that first
May 25, 2019 at 1:21 pm #461660BWG7919
ParticipantHi Dave, when I visit next this hose will get examined, hoses are cheaper than sensors…
May 26, 2019 at 8:34 am #461661iadom
ModeratorNot sure which ‘test mode’ procedure you are trying to use, however there is no mention whatsoever of any button activated test mode for this model in the service manual. As Dave has mentioned a hole rubbed into small pressure hose, often close to where it is clipped to the outer drum at the side is quite a common fault.
May 27, 2019 at 7:26 pm #461662BWG7919
ParticipantCheers iadom / exlectrofix dave, I checked that pipe carefully along with the plastic lower chamber (No idea its official title), no cracks or holes, no rubbing. I noted a nice big sock, possible made from neoprene, around the pipe so in this case there’s nothing for the pipe to rub on. I’ve ordered the pressure switch.
I’m really surprised there’s no engineer mode or test mode as previously mentioned. Even my 15yo LG has the ability to check all major functions in sequence, Another hotpoint, washer/drier I had pleasure to fix had this facility, just bins hours of waiting it to go wrong while it washes socks!..
I tried the 1,2,3 power cycle trick, obviously unique to the hotpoint machine featured in the youtube video, certainly don’t work on the HVL211..
May 27, 2019 at 7:39 pm #461663iadom
ModeratorYou can run a test cycle if you are prepared to fork out over £100 for the hardware key. 😉
What you are talking about sounds like a much older WMA model?
May 30, 2019 at 8:26 am #461664electrofix
Moderatorthat looks like the drum has been rubbing on the drum
must have been making quite a racket
May 30, 2019 at 9:05 am #461665BWG7919
ParticipantGeneral concensus is that a hair clip could have caught on the drum, with a spin cycle it’s end rubbing on the plastic case would have got needle in flame hot and done its damage. I could fit my fingers between the casing and drum and it was roughly where the drum front meets the drum skin rather than the drum front rim.. Either way tiz toast.. For another tenna she can have a brand new machine.. Bit gutted I hadn’t seen it from the getgo..
May 30, 2019 at 9:13 am #461666electrofix
Moderatorhairclip would not have caused that damage you can see its badly melted. no a big bra wire possibly
looks more like drum contact probably the drum spider failed and flexing during spin
anyway yes its another sealed drum failure ( load of tat)
if its under 5 you may be able to claim on the 5 year part warranty but you have to pay for labour.
