Have a Hotpoint HVL 211 Washer faulty – switch on and set programme ok,fills and goes into wash mode ok after ten minutes or so machine goes into drain out mode and door light blinks fast and three lights flash (super wash,quick wash,extra rinse ) then drain pump stops but lights still flash.
Any advice would be helpful thanks
The 4 led’s run from top to bottom. the first is no1 the last is no4. Translate superwash led etc etc. into a number then look the error code up in the “Known Error Codes” thread at the top of this forum….easy!
Is there any Hotpoint specialists out there who can advise on the above problem , also when in spin mode it goes to drain out ok and spins ok but when programme finishes light 1,3.4 flash and door lock light flashes .
Sent module to EMW and returned all ok , now machine working 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} thanks to Tony at EMW
