Hotpoint Iced Diamond
  • #11167
    Can anyone please assist me? I have a Hotpoint Iced Diamond (R134a) which unknowingly just stopped. Light on ok. When the setting knob is turned down to 0 and then put back to a setting it cuts in and runs. It seems to run until temperature achieved and then stops and only runs when the above procedure is carried out again. Does anyone think it may be the thermostat? If so what part would I need and it’s location? Is it easy to change as I am quite confident I could renew it. I would be most obliged for any help. Thanks.
    #144201
    Simon46
    Re: Hotpoint Iced Diamond
    Usually it is the thermostat if it is not getting cold. If you require an engineer check out repairs@ on LHS of page. Unplug first :zap: if you are going to have a look yourself.
    Regards
    Simon.
    #144202
    Daikath
    Thanks Simon for reply. I might have given wrong info in my post. The fridge does get cold ok but cuts out as said. Will it still be the thermostat? Thanks.
    #144203
    Dave_Conway
    Yes, it’s almost certainly the thermostat.
    Without the model number (R134A is the gas type) I can’t check the genuine part for you but the universal one fits most Hotpoint larder fridges:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=147
    #144204
    Daikath
    Thanks Dave. I’ll recheck the model number.
    #144205
    Daikath
    My model number for the Hotpoint Iced Diamond is RL64S. Can anyone please tell me the part number for the thermostat? Most obliged.
    #144206
    Thermostat is p/no 261055 – an email to spares@ukwhitegoods.co.uk quoting that number will get things moving for you.
    beardd
    Hello all –
    I have a Hotpoint Iced Diamond Larder Fridge – the tall one. It’s about 7 years old.
    It has just stopped cooling. The light is on & ok. It was cooling just fine before it just stopped.
    Resetting the thermostat, as noted in the post above, does nothing
    Do you think the thermostat is broken in this case as well ? If so, is it easily replaceable ? If not, is it something else – compressor perhaps ? If the latter, worth replacing or just buy a new fridge ?
    Thanks in advance – David
    #144208
    beardd wrote:Hello all –
    David
    Model number???
    If you turn the thermostat Off, then back On can you hear/feel a distinct click. If not then the thermostat is a strong possiblity.
