I found this post “Came home from hols yesterday to find our Iced daimond fridge ( RL64P, serial 86105306) had stopped working (Not getting cold) and the compressor would not kick in. Bypassed the thermostat and the compressor runs fine so can only assume the stat is dead.”
How do I Bypass the Thermostat to test if mine has the same problem?
Many Thanks for any help you can give me.
D
Not something we could possibly recommend!
If you can get your hands on a mulitmeter and check for continuity between terminals 6 and 4 on the ‘stat (or lack of) this will confirm a duff ‘stat…plug out at all times of course. :zap:
