Hotpoint Iced Diamond FF78
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint Iced Diamond FF78
  • #24660
    sheil
    Hi Guys,
    Seems like i’ve got a similar problem to earlier listings. Except my freezer is -28 and the fridge is generally at between +4 and +5. The compressor seems to be running 90{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time and when it does trip out the air temperature in the fridge goes up to +14 😕 and then drops back down when the compressor cuts in again. Could this be a Thermistor problem? If so, which one, as I understand there are three!
    Sheil
    #202892
    sheil
    Re: Hotpoint Iced Diamond FF78
    I have bought a max/min thermometer and monitored the freezer temperature for a week, it varies between -22 deg and -32deg.
    The fridge is at a fairly constant 10 degrees.
    I have noticed that behind the chiller compartment at the bottom of the fridge the feeder pipe is frozen. This pipe must link the fan at the back of the freezer to the control unit at the top of the fridge. We did a full de-frost two weeks ago.
    Anybody got any idea what the problem is or is it call out the Engineer time?
    #202893
    sheil
    Is there not anybody out there that has had a similar problem or can offer any sort of advice? 😥
