Home › Forums › Public Support Forums › Help And Support › Fridge And Freezer Forum › Hotpoint Iced Diamond Fridge freezer RF64P cooling problem
- This topic has 4 replies, 2 voices, and was last updated 19 years, 4 months ago by
nellmcl.
December 19, 2006 at 1:39 pm #23490
nellmcl
Participanthi Guys
I have a problem with my Hotpoint Iced Diamond Fridge freezer model RF64P. The fridge and freezer appear cold (still frosting in the freezer) but nothing is frozen. When I turn the thermostat in the fridge compartment there is no “click” nor does the fridge make any sort of starting noise. The red light is showing on the outside to say its too warm.
I have “tapped” 🙂 the thermostat area of the fridge and it appeared to start working (like when a starter motor in a car is jammed)
Does this sound like a thermostat problem? Also does the thermostat control the freezer as it appears the problem is with both compartments?
Any help would be appreciated.Thanks
NeilDecember 19, 2006 at 2:06 pm #198304Martin
ParticipantRe: Hotpoint Iced Diamond Fridge freezer RF64P cooling probl
nellmcl wrote:Does this sound like a thermostat problem?
No not a thermostat problem, more likely a coolant or compressor problem? Is the compressor motor running?
December 19, 2006 at 2:19 pm #198305nellmcl
It doesnt appear to be. This may have been what started coincedently when I tapped the thermostat. Is the compressor situated at the rear at the bottom? Would a gentle tap release the motor?
I have this fridge freezer out in the garage. Would the recent cold spell affect the coolant / compressor?
December 19, 2006 at 2:43 pm #198306Martin
nellmcl wrote:Is the compressor situated at the rear at the bottom? Would a gentle tap release the motor?
Yes the compressor is the large black motor at the bottom. It may be that the start relay has jammed/failed and the motor not kicking into life? In any event I think that area is were the fault lies?
:zap: You are reminded that it is dangerous to attempt any inspections without first turning off the power…. :zap:
December 19, 2006 at 2:50 pm #198307nellmcl
Martin wrote:Yes the compressor is the large black motor at the bottom. It may be that the start relay has jammed/failed and the motor not kicking into life? In any event I think that area is were the fault lies?
Thanks Martin
I will look at this tonight and let you know how I get on.Neil
