Hotpoint iced diamond too cold
Home Forums Public Support Forums Help And Support Fridge And Freezer Forum Hotpoint iced diamond too cold
  • #18780
    GreatApe
    My fridge is getting down to just about freezing cold, presumably some sort of senser/thermostat problem.
    I’m trying to work out the model number from all the stuff on the back, the numbers to choose from are RS2518, 225/2631/01, Class SN, 0F700. Hopefully something in that lot makes sense to someone.
    If it’s an easy part to replace I’d like to order the relevant part, thanks.
    #180353
    Re: Hotpoint iced diamond too cold
    Model details will usually be found by pulling out the crisper bins.
    Dave_Conway
    GreatApe wrote:I’m trying to work out the model number from all the stuff on the back.
    Take a look beside the salad bin in the fridge, it’s there 😀
    #180355
    Cooee…….. :wave:
    #180356
    Dave_Conway
    Blimey :wave:
    #180357
    GreatApe
    Penguin45 wrote:Model details will usually be found by pulling out the crisper bins.
    Finally tracked it down, the number was on a sticker on the underside of the lip above the door, well hidden.
    Model No:
    RL61P
    33100218
    #180358
    Dave_Conway
    It does sound like the thermostat is at fault.
    Part number for this model is 261055 at £22.49 inc.
    An email to spares@ukwhitegoods.co.uk please if you’d like one, remember to power off when checking :zap:
    If you’re unsure on fitting, please try the repairs@ link below for an engineer 🙂
